4.10 pinion gear carnage
Old May 6, 2006 | 12:04 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
every single tooth is cracked somewhere, but only 3 came all the way off
Old May 6, 2006 | 01:36 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Ive done that to a few sets with my 5 speed. You got an auto??
Old May 6, 2006 | 01:48 PM
mw66nova's Avatar
Engine: 7.0L
yep, and a 4000stall ati 10" converter.
Old May 6, 2006 | 10:24 PM
rjmcgee's Avatar
Did that have a crush sleeve or a solid spacer in it?
Old May 6, 2006 | 11:42 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Im no expert by any means but looking at your gear wear it looked normal. so im guessing this is a result of your pinion walking up your ring gear. you must used a crush sleeve correct?
Old May 7, 2006 | 12:44 AM
mw66nova's Avatar
Engine: 7.0L
yes, i used a crush sleeve...should have used a solid one, but you know...hindsight is 20/20...the wear on the gears looked great, you could probably clean the edges of the ring gear up and re-use it...well, maybe not, but the ring gear does still *appear* to be in good shape.
Old May 7, 2006 | 06:17 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Hey if your lookin at gettn another set of gears the last set I bought I found a company that warrantied them, yes WARRANTIED THEM. I told them that I would break them and they ensured me that it was no problem. Their moto was " Break them, Burn them up, Install them wrong, Their warrantied" Broke them 10 passes later and it took some time to get them but I got them.
Old May 7, 2006 | 08:39 AM
rjmcgee's Avatar
When set up properly the ring and pinion are not usually the weak link in the rear end.
Old May 7, 2006 | 02:16 PM
mw66nova's Avatar
Engine: 7.0L
when you have a crush sleeve instead of a solid pinion spacer, and there is flex in the case, it doesn't matter how you set them up, you're gonna break something. they had great wear pattern on them and never made a sound...
Old May 7, 2006 | 08:05 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
3rd gen + stick tires with low psi + 3500-4000 rpm launches = weak link.
Old May 8, 2006 | 12:16 PM
Shagwell's Avatar
Car: projects.......
the gears themselves aren't the problem, but they're what usually breaks. As stated, crush sleeve + case flex = slack in the pattern which eventually = POP
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
