Difference in 9bolt vs 10 bolt
Old May 7, 2006 | 10:23 PM
km7152's Avatar
Car: 1991 Camaro Rs
So i've looked into this a little bit, but still not seeing a huge difference. Not looking for anything crazy, but whats the better option and why? Any mechanical/physical difference (besides the 1 bolt) Thanks
Old May 7, 2006 | 11:35 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
They appear to be completely different except for the bolt patterns on the axles and the way the disc brake set up installs and works. The internals are different. Go to your local chevy dealer and ask about getting bearings, seals, gears, etc. for the borg warner 9 bolt and you'll probably get the same response I did,"I can order parts, if I can find them, but I won't guarantee anyone in the network has the parts."
Old May 7, 2006 | 11:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The bolt patterns on the axles and the brake setups are identical between the two. Absolutely nothing else interchanges though. They're entirely different internally.
The 9 bolt is considerable stronger than 10 bolt. If I was looking for a rear-end for average street use though, I'd get a 10 bolt and strengthen it. The scarcity of parts for 9 bolts makes them not worth the trouble as far as I'm concerned.
If I was going to be racing it or abusing it in some way, I probably woudn't bother with either, and I'd be buying a 9 inch or 12 bolt or something.
Old May 8, 2006 | 12:36 AM
km7152's Avatar
Car: 1991 Camaro Rs
Ya i figured neither of them were worth building up, but thats pretty much what i was looking for. It was kinda just something that made me wonder everytime i saw 9 bolt or 10 bolt listed. What can be done to strengthen the 10 bolts without getting too crazy?
Thanks Guys
Old May 8, 2006 | 12:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Welding the axle tubes, using a solid pinion spacer, stud girdles, aftermarket axles... A search or a check of the tech articles will turn up all the ways to strengthen a 10 bolt.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
onefreakz
May 14, 2018 12:15 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
