Car vibrates going into reverse and first
Old May 10, 2006 | 12:58 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I recently converted the car over to a manual (700r4 to t-56). Spohn crossmember, TA, etc. I'm still running the stock prom but I'm not sure if it would matter. I'm running a poly mount on the torque arm and a poly trans mount. I'm still using the old stock rubber engine mounts. The engine hung on the two mounts unsupported during the install but it drives fine under throttle so I'm guessing the engine mounts are fine.
When I engage first gear or reverse the car shakes like no other but it stops as soon as the clutch is fully engaged. It also makes a weird knocking sound around tight corners at full lock, like in parking lots, etc. I’m not sure what’s hitting what but something has to be hitting something and it wasn't happening before the swap. When the weight of the car shifts forward/back there’s a squeak that comes from under the car like when I swap from engine braking to acceleration.
I'm not sure if everything is related but if anyone has any advice it's more than welcome.
Old May 10, 2006 | 05:46 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the shuddering sounds like you have a nasty clutch chatter problem. This is caused by the clutch plate not engaging squarely on the flywheel. Make sure the pinion angle is correct and all the hydraulics are in good working order.
Old May 10, 2006 | 01:20 PM
Gummie's Avatar
Car: 88 GTA
I would like to think that it's not chatter. I bought everything new specifically to avoid things like this
Spec stage 3 clutch, Centerforce billet steel flywheel, and new hydraulics from TPI parts. I’m running 4th gen pedals if it makes a difference.
It's possible that oil is getting onto the flywheel but I remember this happening pretty much from day 1. It is possible that pinion angle is off (the angle between the TA and the DS, correct?) but I don’t see how that would cause chatter?
Old May 10, 2006 | 02:43 PM
1981LT1's Avatar
Engine: LT1; LT1
With everything new and matched, I would agree that it is probably not clutch chatter. The pinion angle will cause wheel hop which could be felt like chatter if it isn't that severe.
Old May 11, 2006 | 06:49 PM
Gummie's Avatar
Car: 88 GTA
The knocking is MUCH worse in reverse than it is in 1st. Any reason why this would matter?
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
mizz0313
Aug 12, 2015 06:45 AM
bryan623
Aug 10, 2015 11:33 AM
hokis
Aug 9, 2015 03:57 PM
