Speedo Correction
Old May 10, 2006 | 11:51 PM
Abanda's Avatar
Speedo Correction
ok my 91 formula currently has 3.73 rear gears and 15" rims in the back. I know that my car came with 16" rims and smaller gears in the rear. My speedo is currently off by about 10 mph. I am swapping in a 4th gen rear with 3.42 rear gears and also some 17" rims. What should i do to make sure that my speedo is the correct mph?
Old May 11, 2006 | 12:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Change the speedometer gears in your transmission to match your differential ratio and tire size.
Old May 11, 2006 | 05:39 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
BTW, it's not the rim size that matters, it's the overall height of the tire that is going on the car.
Old May 11, 2006 | 07:04 PM
Abanda's Avatar
oh ok sorry. i am looking at getting some 275/40/17 on all four corners.
Old May 11, 2006 | 07:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you've got a 15 tooth gray drive gear, then you need about a 41 tooth yellow gear on the VSS, P/N 25513048.
Old May 11, 2006 | 07:21 PM
krisb410's Avatar
You will need a 17 tooth drive gear and a 45 tooth driven gear, this will be more accurate.
How to install the speedo gears
Old May 11, 2006 | 07:24 PM
Abanda's Avatar
could i just go to autozone or any local shop? or do i have to venture over to a dealership?
Old May 11, 2006 | 07:26 PM
krisb410's Avatar
Dealership, about 6 bux a gear.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
topteam54
Oct 6, 2015 12:21 AM
TrevinE
Sep 14, 2015 03:20 PM
