MORE t-56 questions..
Old May 10, 2006 | 11:52 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
I dont think this one has been covered yet.. I got my t-56 on the ground (got it from a friend) and I can go through all the gears (1 through 6) fine BUT I cant get it into reverse. Two things come to mind.. either..
- the trans has to be bolted up to the engine.......... or (reverse is all the way to the right and up)... right???
- this is NOT t-56.
Dan
Old May 11, 2006 | 12:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Wire up the reverse lockout solenoid, or remove it altogether.
Old May 11, 2006 | 08:19 PM
dyrt's Avatar
Car: 86 Regal Limited
Engine: 95 cop lt1
Transmission: t56
Axle/Gears: 8.5" gn/3.73 gears
have someone hold it tight for you and put some muscle into it. there is a lockout solenoid that can be easily overpowered. mine is in an engine stand and i can do it, but it was much harder to check reverse when in was on the floor. search on the forums about work arounds for reverse lockout, most people wire a momentary switch to unlock it for shifting and some put a switch on the brake. others leave it unhooked and just give a little hell to shift into reverse. it is computer controlled by the pcm in the cars it came in.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
'91 Formula
Nov 25, 2001 04:58 PM
