Should I use my Mcleod clutch
Old May 14, 2006 | 07:41 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
I was just reading an article, and i'm questioning wether or not to use this clutch I just bought. I have a pretty stout 355 and I had no problems with the transmission before. I didn't put that much mileage on it, and when I took it apart I found a valeo clutch disc in it. I was amazed that it worked as good as it did.
The clutch is a street/strip version thunder racing sells it, it has a segmented disc with 6 pads I think. I read that using a clutch this type puts a lot of stress on a transmission, because of the initial jerk, if you shift fast and let up on the clutch fast. I consider myself good at driving stick and i'm not going to be abusing the car that much. When I beat on it, I know how to shift properly. I'm also using a lightweight flywheel. thanks
Old May 15, 2006 | 09:18 AM
Should be fine, if treated with reasonable care.
Old May 15, 2006 | 11:25 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
thanks man, I appreciate it. I just wont be able to afford to rebuild the trans his summer, and I can't affort to have the car off the road to service it. I went throught the whole trans myself, it should hold up till I build my next motor.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
topteam54
Oct 6, 2015 12:21 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
