700r4 transmission question
Old May 14, 2006 | 10:31 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
well i have an 1984 pontiac firebird with the carb 2.8l with the 700r4 trans. well i was thinking about swapping the 2.8l with a 305. will my current trany bolt up to the 305? If not what will work?
Old May 14, 2006 | 10:58 PM
brown91redcam's Avatar
Car: 1991 Camaro Z28
Engine: '96 350 vortec tpi
Transmission: 700R4 transgo reprogramming kit,tra
Axle/Gears: 10 bolt 3.73 eaton posi unit
The 2.8 trans will not interchange with your 305,you will need a trans from a 700r4 from a v8 car.
Old May 14, 2006 | 11:41 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
the 700r4 doesn't necessarly need to be from a v8 car....large v6 have the right 700r4. it just needs to be from a 90 degree block...like all v8 cars. the 2.8 has a 60 degree block
Old May 15, 2006 | 12:39 PM
Car: 84' Trans Am
will the 700r4's from the v-8 car bolt in to the car with no problem?
Cleotiz
Jan 6, 2018 08:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
