TCC and TV
Old May 15, 2006 | 08:54 AM
LittlejohnLJ88's Avatar
Car: 92 Camaro RS
Engine: 350 Modified
Axle/Gears: Stock
TCC and TV
I have a 92 RS with a 700R4 and a modified 305. We put an intake and carb on it and striped the computer out, changed ignition system and distributor. My problem is that I can't get the TV cable adjusted properly because the throttle cable and TV cable bracket is diffrent on a carb than the TBI, also with the computer out Im not positive but I think the torque conveter isnt locking up. If anyone has any info it would be extremely helpful. I have had this problem for months and have been trying to figure it out.
Old May 15, 2006 | 01:00 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
What kind of carb did you install?? The type of carb can dictate the potential TV cable geometry fixes available... As to the torque converter lockup issue, there are a few ways to wire it up.. Search around the boards for some info on some of these configurations..
Old May 15, 2006 | 01:39 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
w/ thirdgen88
Do not drive the car without the correct bracket and TV cable geometry. 700-R4s rely on those more than just the kickdown passing gear, they control fluid pressure. If it's to tight or to loose it's easy to junk out a good transmission.
Old May 15, 2006 | 09:44 PM
Car: 92 Camaro RS
Axle/Gears: Stock
It,s an edelbrock carb, I actually ordered the "correct" bracket that yearone had in their book for 82-92 camaro, it was for edelbrock carbs throttle/kickdown cable bracket, then installed it and still didnt work right, so I took it to a transmission guy to work on it, when he was done he said it still didnt shift right but he did the best he could without ordering anything else. I can drive and it wont shift untill 4 grand or so, unless when I get to 1500 or above I can let off the gas completly and it will shift and then I accelerate in that gear doing the same thing to go to the next.
Old May 15, 2006 | 09:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Have you got a picture of that bracket? or a link?
What TV cable are you using?
UltRoadWarrior9
Apr 28, 2020 10:39 PM
jklein337
Sep 19, 2018 06:23 PM
92camaro350cci
Oct 14, 2015 09:29 AM
ramicio
Sep 28, 2015 01:18 PM
Mark 89Formula
19
Jan 5, 2004 04:14 PM
