What else do I need for my 4th gen rear?
Old May 21, 2006 | 05:43 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I have a 4th gen rear from a LT1 car. Posi 3.42.
I have the calipers, disc, all the hardware (bolts) for the brakes, and the t-brake line that runs along with the rear itself.
What else do I need to install this rear? Links to summit would be helpful or if anyone has the parts and are willing to sell as well.....or just any info at all.
Old May 21, 2006 | 05:52 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
gear oil and silicon.
Old May 21, 2006 | 07:01 PM
crrllmich's Avatar
Engine: L03, LS1
What abour my emergency break? and poportioning valve.
Old May 21, 2006 | 07:39 PM
Zepher's Avatar
what about them?
you didn't say if you had drums or disc originally.
e-brake cables need to be modded or changed and modded.
prop valve can be changed if you had drums but I am running the stock drum prop valve with my LS1 rear brakes with 92 Camaro e-brake cables with no issues.
Old May 21, 2006 | 08:22 PM
crrllmich's Avatar
Engine: L03, LS1
Awesome.... I know I am gonna sound dumb for this but whats the silicon for?
Old May 21, 2006 | 09:28 PM
Zepher's Avatar
silicone for the diff cover if you don't use a gasket. I always use silicone and never had any problems. just try not to get any in the bolt holes.
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
