Trans temp gauge questions
Old May 22, 2006 | 01:19 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I did a search but still have a couple of questions about the sending unit and install locations. I read in the posts about installing the sender in place of one of the case plugs. Does anyone here have a pic of such an install? And second, in the pan installs seem to be one of the preferred methods so where in the pan is the best location that won't interfere with the valve body and provide adequate ground clearance? Pics of that install would be appreciated as well.
Old May 22, 2006 | 04:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I have mine mounted in the back of the pan.
Old May 22, 2006 | 04:46 PM
Mongoose's Avatar
Car: 90 Formula
Thanks for the reply. You wouldn't have a pic of it by chance?
Old May 22, 2006 | 05:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I have a powerglide. On the backside of the pan towards the passenger side, I drilled a hole and installed the sending unit. There's enough room there in the powerglide that it doesn't touch the valve body or anything else.
Old May 22, 2006 | 06:25 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Drivers side, about 3 inches from back, vert center.
That is where mine was installed (came from BowTie that way)
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
gta power
Aug 13, 2015 06:15 AM
