Problem,Tranny or converter?
Old May 29, 2006 | 11:43 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I am starting to have a wierd problem with my tranny.While cruising up hill with light throttle I notice that the car seems to stumble but it feels more like the tranny.Not really a stumble but like a slip.The rpm's raise about 1-200 rpm for a split second then drops back down and when I give it more gas it's fine.I am getting a shake in the engine at about 1,500-2,300 rpms and I think it's the torque converter.Would a bad torque converter give that "slip" porblem?When other trannies have gone out on me it's a really noticable slip but this one you have to be paying attention too to feel.The tranny is full and works flawless everyother time.
Old May 29, 2006 | 01:06 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
sounds like your lugging the engine. that 1-200rpm increase is most likely the TCC disengaging
Old May 29, 2006 | 01:34 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yeah it almost feels like it's lock and unlocking constantly.If I give it more gas or if I let off it stops.
Old May 29, 2006 | 02:12 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
bridge the termanals on your ALDL to lock the tourque converter (a and g i think, the two top outside ones) and try and re-create the problem. if it no longer happens it is your TC unlocking and locking.
dyeager535
Aug 28, 2015 08:10 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
