new 700 with 3200 stall...which trans cooler and where to put the temp sender?
Old May 31, 2006 | 01:12 PM
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
well after alot of phone calls to transgo, it turns out the original 700 has an internal pressure leak after 150 psi...so new trans time. i just put a 3200 9" stall converter in and when i get the new trans, i would like to be able to cool it properly. what trans cooler should i run and where does the transmission temp sender mount to the 700r4?
thank you again
Old Jun 1, 2006 | 06:42 PM
MdFormula350's Avatar
i would think u need to drill a hole in the pan for the temp sendor/sensor/gauge setup.
anyway i am having great results with the - B&m super cooler 24,000 GVW, got it from jegs i believe.
Old Jun 1, 2006 | 06:59 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
exactly
Old Jun 1, 2006 | 10:57 PM
pmpnavt's Avatar
Engine: L98 350
put the sender just anywhere or a specific side?
Old Jun 2, 2006 | 03:40 PM
Tobias05's Avatar
I'd prolly put it on the passenger side, "should" be the best location, away from the shift linkage, inspection cover, and tranny mount.
I need to tap my tranny pan too! I've got the gauge all hooked up, just need to install the sensor...
Maybe I'll do that one of these days...
Old Jun 2, 2006 | 03:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Put it anywhere in the pan where it will clear the valvebody and guts inside. Mine is on the driver side.
Old Jun 2, 2006 | 03:53 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Drivers side, about 3" from rear, slightly below center vertical.
Also the B&M 70264 works ok on mine
camaro11j
Sep 19, 2018 08:49 AM
NBrehm
Aug 25, 2015 11:49 PM
TreDeClaw
Aug 14, 2015 06:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
Leggman1
Aug 6, 2015 04:15 AM
