Need help with gear ratio selection
Car: 1987 Iroc Z
Engine: 350 ci.
I have a 9bolt rear with 3.27 gears in it. I am wonder what is best gear choice for gear's and where is least expensive place to get them. I drag race this car and only going thourgh the lites at like 4600 rpm. I also drive it on the streets. any help would be great.
Car: 1987 Iroc Z
Engine: 350 ci.
My trapp speed is 101 mph and My tire size is about 25.5". I am night quite sure on the tire size. I am using a 15" rally with like a 245 50 15 tire. I will be getting some good drag tires and rims soon. Some pro stars maybee. I will proabally ask about that to when I am ready.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
with 3.73 gears and u should hit around 5.1 - 5.2k rpms. should be good for a tpi setup. if u run taller tires such as with drag radials or slicks, u can get more gearing out of it.
Car: '02 Z06
Engine: L33 5.7
now thats the tricky part, finding parts for a 9 bolt. can't help u there. but from where u stand now and in the future, 3.73 gears would be perfect for you.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not sure if he's still in business but try www.diffsolutions.com 9 bolt parts are hard to find. If you order from Australia, you can get lots of stuff since that's where they're made.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
