up the passenger's butt
Old Jun 4, 2006 | 02:42 AM
19Irocz86's Avatar
Car: 1986 Iroc z z28
Engine: 305 tpi
i have a 1986 IROCZ with a 305 tpi and 700 r4 well the other day i back off a drive way bout a 7 inch drop and it hung teh bottom of my car preety good since then when i get on the gas a little hard something slams up and hits real hard under the passenger seat or in the trans/shift tunnel i cant really tell. but i got under it today and look to see if teh tranny mount went out.. nope it was fine all the bolts were tight as far as i chould tell and the torque arm is fine too.... any suggestions what it chould be?? the first time i notice it when i punched it at the red light it bang real hard bout 2 or 3 times.. now it does it just once....
its like when the body shifts backwards because of the massive torque machine " THE 305" hahah it throws the trans up into the bottom of the car but i jacked the trans up a little and it was tight as chould be??? help me
Old Jun 4, 2006 | 05:35 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
sounds like U broke the tranny mount, U uasally can't tell it's broke just by looking at it, U have put a jack under the transmission and put allitle pressure on it, if the mount is broke it will seperate, R2ing it is farily straightforward, I reccomend getting a polly one, as the rubber ones are notorious for breaking
Old Jun 4, 2006 | 06:34 PM
19Irocz86's Avatar
Engine: 305 tpi
i jacked it up and it pulled the body up with it.... no sepration, and it makes me kinda nervous driving it... i dont want to make it worse
Old Jun 5, 2006 | 10:47 AM
19Irocz86's Avatar
Engine: 305 tpi
anyone
Old Jun 5, 2006 | 11:47 AM
AC's Avatar
AC
Car: Used to drive a camaro
19iroc, you couldn't smacked the cat's....but you'd see a pretty deep crease/dent in the heatsheields if that were the case. Look around the ypipe to see if anything looks "shifted" or too close to the frame etc. other than your tranny mount breaking that'd be the only thing I could think of. I once drove off a 4" curb...the lot actually had a curb end that was flush with the next lot 4" inches below it and that's what I didn't see before it was too late. No damage but a LOT of swearing.
If you get a bang,slap,etc when you punch it I'd swear it's DEFINETLY the tranny mount. I've gotten the same thing when I broke 4 OEM mounts and 2 energy suspension mounts. That was with a stout 350 and TCI streetfighter 3 speed though. But the same result, I'd punch it and hear what sounded like a hammer slap the tranny tunnel.
Old Jun 5, 2006 | 11:18 PM
19Irocz86's Avatar
Engine: 305 tpi
im just gonna replace the trans mount and see... but i have no cats or resanator on my car i cut them off.... also when i replaced my transmission maybe i threw the exhaust off or something but i replaced the transmission about 6 months ago and it just started making the noise
Old Jun 9, 2006 | 01:18 AM
19Irocz86's Avatar
Engine: 305 tpi
the trans mount was broke... turns out when i jacked it up teh bored i used to support the pan was to long and hung on the sub frame lifting the whole car and making me out to be a dumb *** but i changed the mount and it was broke... thanks
Old Jun 9, 2006 | 06:04 AM
AC's Avatar
AC
19Iroc, good to hear your back on the road. Whatever you ran over probably didn't cause the failure but more so launching the car or peeling out. The mounts break usaully before anything else.
MrPackstin
Oct 25, 2017 08:09 PM
Briandrex
Oct 5, 2015 06:20 AM
sjorgens
Oct 1, 2015 07:54 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
