WHERE CAN I FIND A CRUSH SLEEVE FOR A BORG WARNER 9-BOLT?
Old Jun 4, 2006 | 10:01 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
I have the infamous borg warner 9-bolt rear in an 87 iroc. I need to change the pinion seal but I can't seem to find anybody that sells the crush sleeve for this rear. GM is telling me that it has been discontinued, so HOW THE F*** DO I FIX MY REAR?!?!?!?! Any help would really be appreciated. Thanks in advance.
Old Jun 4, 2006 | 10:21 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
ahhh, you have just discovered one of the joys of owning a 9bolt!
Hard to find parts!!!
Ratech part #3101
www.ratechmfg.com/gmstandard.htm
Old Jun 5, 2006 | 08:58 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Rear End
I also have the 9-bolt borg warner rear end, so thanks for the website link. I am pretty sure that I have the 2.73 gear ratio. Is it possible to buy a replacement gear to make it a 3.43 or 3.73? If so, where can I purchase it and how hard is it to install?
Thanks!
Old Jun 5, 2006 | 09:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
oh god!
Parts are hard enough to find for the 9bolt, im not sure if your going to have much if any luck finding anything other than 2series gears to fit your carrier.
If its 3.43+ it wont be too bad but 2 series aint going to be fun.
Old Jun 5, 2006 | 09:13 PM
Car: 87 IROC
Engine: 5.7 TPI
84Z,
Thanks for the link. I've actually been to that site in the past and completely forgot about it, so thanks for the reminder. I think I'll order a few to justify the shipping and save some time in the future.
Old Jun 6, 2006 | 06:53 PM
gta87ls1's Avatar
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
Pinion seal
Hey I dunno if you know this but if you are just changing the pinion seal theres no reason to change the crush sleeve. If you change the crush sleeve you are gona pretty much have to take aprt the whole rear end.
Old Jun 6, 2006 | 11:59 PM
Car: 87 IROC
Engine: 5.7 TPI
That's what I thought when I originally changed the pinion seal. But apparently there was a preliminary procedure that I was supposed to follow before removing the pinion nut. I have had this car for nine years and the only thing that I have had to do to the rear was change the oil. About two months ago the seal finally went. I didn't know that I needed to check preload and sh** to change a f*****g pinion seal. Didn't need to with the ten-bolt. Anyway the seal still leaks and I have no preload reference to go by if I am to follow the proper procedure for the removal and installation of the pinion nut. I figure that if I replace the crush sleeve when I change the pinion seal again, I should be able to use the preload torque for a used pinion bearing(about 7in lbs). Unfortunately, as you mentioned, that means that I have to rip the f*****g cover off again. Well, at least the rear will get some fresh oil. If anyone knows otherwise, any useful advice would certainly be appreciated. Thanks in advance.
Old Jun 7, 2006 | 08:53 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Jaws Gear & Axle</title>
<script language="JavaScript">
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.0
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && document.getElementById) x=document.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<script language="JavaScript1.2" src="fw_menu.js"></script>
<script language="JavaScript1.2" src="topright/fw_menu.js"></script>
function MM_displayStatusMsg(msgStr) { //v3.0
status=msgStr; document.MM_returnValue = true;
function MM_findObj(n, d) { //v3.0
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document); return x;
function fwLoadMenus() {
if (window.fw_menu_0) return;
window.fw_menu_0 = new Menu("root",111,19,"Arial, Helvetica, sans-serif",12,"#000000","#ffffff","#ffffff","#080d18");
fw_menu_0.addMenuItem("Ring &amp; Pinions","location='ring.php?cPath=21'");
fw_menu_0.addMenuItem("Positractions","location='posi.php?cPath=31'");
fw_menu_0.addMenuItem("Lockers","location='lockers.php?cPath=31'");
fw_menu_0.addMenuItem("Installation Kits","location='installkit.php?cPath=24'");
fw_menu_0.addMenuItem("Axle Shafts","location='axles.php?cPath=23'");
fw_menu_0.hideOnMouseOut=true;
fw_menu_0.writeMenus();
} // fwLoadMenus()
function MM_nbGroup(event, grpName) { //v3.0
var i,img,nbArr,args=MM_nbGroup.arguments;
if (event == "init" && args.length > 2) {
if ((img = MM_findObj(args[2])) != null && !img.MM_init) {
img.MM_init = true; img.MM_up = args[3]; img.MM_dn = img.src;
if ((nbArr = document[grpName]) == null) nbArr = document[grpName] = new Array();
nbArr[nbArr.length] = img;
for (i=4; i < args.length-1; i+=2) if ((img = MM_findObj(args[i])) != null) {
if (!img.MM_up) img.MM_up = img.src;
img.src = img.MM_dn = args[i+1];
} else if (event == "over") {
document.MM_nbOver = nbArr = new Array();
for (i=1; i < args.length-1; i+=3) if ((img = MM_findObj(args[i])) != null) {
img.src = (img.MM_dn && args[i+2]) ? args[i+2] : args[i+1];
} else if (event == "out" ) {
for (i=0; i < document.MM_nbOver.length; i++) {
img = document.MM_nbOver[i]; img.src = (img.MM_dn) ? img.MM_dn : img.MM_up; }
} else if (event == "down") {
if ((nbArr = document[grpName]) != null)
for (i=0; i < nbArr.length; i++) { img=nbArr[i]; img.src = img.MM_up; img.MM_dn = 0; }
document[grpName] = nbArr = new Array();
for (i=2; i < args.length-1; i+=2) if ((img = MM_findObj(args[i])) != null) {
</script>
<link rel="stylesheet" type="text/css" href="stylesheet.css">
</head>
<body onLoad="MM_preloadImages('topright/sidemenu_r2_c2_f2.gif','topright/sidemenu_r4_c2_f2.gif','topright/sidemenu_r6_c2_f2.gif','topright/sidemenu_r8_c2_f2.gif','topright/sidemenu_r10_c2_f2.gif','topright/top_r2_c2_f3.gif','topright/top_r2_c2_f2.gif','topright/top_r2_c2_f4.gif','topright/top_r2_c4_f3.gif','topright/top_r2_c4_f2.gif','topright/top_r2_c4_f4.gif')">
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>osCommerce
Try these guys. They appear to have just about anything you'd want for a BW 9 bolt.
Why does this link keep coming up looking like this. Any idea what I'm doing wrong?
Old Jun 7, 2006 | 09:19 PM
Yeah, you're linking to a Java script (database lookup) instead of a web page.
Old Jun 7, 2006 | 09:26 PM
Car: 87 IROC
Engine: 5.7 TPI
Yo Z, thanks a lot man, that site is great. I'll keep them in mind when I upgrade to 3.73's. hopefully in the near future.
Yeah....Java script......that's exactly what I was thinking......java script....
Last edited by 87IROCZ350TPI; Jun 7, 2006 at 09:28 PM. Reason: Automerged Doublepost
GTAman
Jul 3, 2024 07:29 PM
jtwoods4
Jan 22, 2018 01:13 PM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
