what should I use for a tranny?
Old Jun 12, 2006 | 09:21 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
Over the summer and winter I'm going to be building an engine for the formula. With the parts I'm planning to use, it should have well over 400hp. I have been looking into transmissions from jegs and was wondering if they were any good? Should I go with their brand new th350 or get my 700r4 beefed up If I can. Which would be cheaper?
Thanks guys, Randy
Old Jun 12, 2006 | 09:36 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
You can get a stout TH350 that will be a good performer but you will be limited to what gears you can run. A 700R4 will be a bit more expensive but you will have the deeper first gear and OD. Either one can be built to handle the motor. Keep in mind, the horsepower is not what kills the trans, its the heat and the torque.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
