Do I need an adjustment or something worse is happening?
Old Jun 15, 2006 | 01:12 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Hello,
I just bought a 1989 Chevrolet Camaro IROC-Z, 350 TPI, 4 speeds automatic transmission, 2.73 POSI...
When I floor it from a stop, the 1-2 shift always go fine, but when it should shift to 2-3, it just doesn't shift 90% of the time and I have to let off the gas pedal a little so it shift in 3rd.
What is wrong? If it's an adjustment, how do I do it the right way? I don't wan't to burn my transmission with improper adjustment.
Thanks and see ya!
Old Jun 15, 2006 | 01:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Search for TV cable adjustment
It may not be the problem but at least it would eliminate it.
Old Jun 16, 2006 | 02:40 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I'll have a GM mechanic adjust it to factory spec next week, hope it'll help! I wanted to drag witht he car 1-2 july... It would look bad in the middle of the race, my car don't wan't to shift in 3rd lol.
I'll also make them change the tranny oil, filter and gasket. They will also change the rear end fluid and gasket.
So I should be good with that I hope.
Old Jun 17, 2006 | 09:12 AM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Mine does the same. It always gets almost to 6 grand and I have to let off a little to let it shift. I've changed my filter and fluid and tried to adjust the TV cable but mine won't rachet so I'm gonna get a new cable but if that don't work I guess its the trans. Hopefully not!!!!!!!!
Old Jun 27, 2006 | 04:27 AM
91z28tpi355's Avatar
Mine is doing the exact same thing, so if anyone finds out what the problem is, please let me know.
Old Jun 27, 2006 | 11:33 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
My GM mechanic adjusted it, but now it shift below 4000RPM from 2-3... Pretty weird
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
