Clutch Pedal Stopper?
Car: 1982 Z28
Engine: 355 V-8
Transmission: Super T-10
Where can I get a clutch pedal bumper/stopper for my 1982 Z28. Mine is missing. This is the rubber stopper that has a threaded end on it and attaches to the metal shaft in front of the clutch pedal.
Thanks ahead of time for the help!
Snowman
Snowman
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I have the same trans here. I can't think of this part.
You mean a stop to stop you from pushing in the clutch too far? In the passenger compartment?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
i have no clue sonix
, sounds like a stopper to hold the pedal from coming back up too far...
, sounds like a stopper to hold the pedal from coming back up too far... Last edited by 84z28350; Jun 21, 2006 at 02:02 PM.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
uhhh... i think i know... do you have anything else on that "stoper" holder? i think you are thinking of the hole for the clutch sensor switch, it screws in ... well why tell you when i can show you, i happen to have a picture because i rule. ok, it looks like there is only one thing that can fit there, if you are missing that giant white plastic thing it is the switch that makes it so you cannot start the car without the clutch depressed. there should be a brown and yellow wire under the dash somwhere that somone has spliced together, these go to that switch.
as far as a stopper.... i don't have one on my 5 speed either
Car: 1982 Z28
Engine: 355 V-8
I do have the clutch switch. The part that I'm missing is a rubber stopper that would go in front of the clutch pedal, towards the top. When you turn it counter clockwise, it would move towards the firewall and take out the looseness of your clutch pedal. My clutch pedal as about an 1" or so of play in it. It rattles when it's not engaged. I have to use my foot and pull it towards me to make it stop rattling.
It's basically an adjustment bumper for taking out any play in the pedal.
Hopefully, I'm not blowing smoke or doing smoke on this one!!
Car: 1982 Trans-Am
https://www.thirdgen.org/forums/tran...ustment-t.html
"no actual stopper on these cars".
Your car should have a spring on the clutch adjustment fork that holds it enough to keep it from rattling.
Car: 1982 Z28
Engine: 355 V-8
Thanks, Sonix.
I will check my spring. I just put in the new engine and clutch assembly. Maybe my spring is toast.
