gears.....
Old Jun 19, 2006 | 07:18 PM
gmtekk's Avatar
gears.....
any one know wat gears come in an 89 iroc 5.0tpi.....its a 10 bolt...both tires leave a nice even burn out...but i was thinking of upgrading to may be 373s
Old Jun 19, 2006 | 09:29 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Wow, how vague can this answer be. You need to visually inspect the ring and pinion to make sure of the ratio. Even with the RPO codes, you never know if they have already been replaces.
Old Jun 20, 2006 | 03:29 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
3.73s....too deep for stock or slightly lukewarm motor. 3.4X would make you happier. There are a number of gearsets that could be in your car. You'll have to read the numbers stamped on the ring gear to know for sure.
88fastgta
Jun 19, 2011 08:26 PM
92droptopws6
Mar 8, 2011 01:18 AM
85T/A
Nov 23, 2009 07:09 PM
graymaro87
Oct 7, 2009 12:39 PM
88fastgta
May 4, 2008 11:35 PM
