reverse input piston
Old Jun 21, 2006 | 04:07 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
Ok here is one for you guys, how are u suppose to put the piston in with the lip seals on without damaging them
Old Jun 21, 2006 | 09:59 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
petroleum jelly, patience, and a lip seal installer.
Old Jun 21, 2006 | 10:03 PM
Car: 87 trans am
there is no lip seal installer with the reverse input clutch i dont think, there is one for the forward clutch and the overrun clutch
Old Jun 22, 2006 | 05:42 AM
1981LT1's Avatar
Engine: LT1; LT1
the lip seal tool works for all the pistons. You have to keep slight pressure while running the tool around the circumference.
Old Jun 22, 2006 | 12:40 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
A .005 feeler guage works in a pinch.
Old Jun 22, 2006 | 04:11 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The lip faces into the case, so you need a lip seal tool or a feeler guage to get it in without damage. I like to use a tapered feeler gauage that is about .022" thick. Works just fine if you can't get the tool. They tool is only about $10 though, and a NAPA or good auto parts store will either have one or can order it for you.
cheesehomer
Dec 31, 2015 08:48 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Linson
Oct 1, 2015 09:50 PM
