What transmissions fit 84 305?
Old Jun 25, 2006 | 02:15 AM
BLK84ZED28's Avatar
Car: 1984 Black Z28 Camaro
I have no drive but 1st, 2nd, od and reverse work. My neighbour said I can have his tranny from an 82 chev van that has a 350 in it, will it fit?. How can I tell what transmissions will fit?
Old Jun 25, 2006 | 02:31 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
any chevy trans with the large bolt pattern will bolt to any chevy block with the same bolt pattern IE small blocks/big blocks and some assorted V6s and I4s. so it will almost 100% assuredly bolt to the engine the fun part is if it is the same Length and has the same trans mount point as the camaro/firebird trans. if its anything other than a 700R4 or T5 it will be a different length and have a different trans mount. there are different od combos on chevy trans that will fit properly but for the most part they will need a custom DS and crossmember.
First find out what the trans is and them some of the more knowlagable people on here will be able to help more.
Old Jun 25, 2006 | 03:02 AM
BLK84ZED28's Avatar
xplane
ahh.. I didn't even factor that it would mount diferently or be diferent length.
can I fix this trans myself?
Last edited by BLK84ZED28; Jun 25, 2006 at 03:05 AM. Reason: Automerged Doublepost
Old Jun 25, 2006 | 08:55 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
You also need to be concerned with how you will mount the torque arm. From what I've heard (I have a T-5) - the TH 350's for F-body's have a shorter tailshaft housing with a torque arm mount. I'm sure someone with a automatic could expound on this??
Old Jun 25, 2006 | 11:36 AM
BLK84ZED28's Avatar
Does anyone know how to diagnos this problem so I know if its bands or clutch plates or whatever you?.
thanks for previous info..
Last edited by BLK84ZED28; Jun 25, 2006 at 11:37 AM. Reason: Automerged Doublepost
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Apr 30, 2019 12:14 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
theurge
Aug 21, 2015 12:46 PM
