Output Shaft Bushing Wearing Out HELP!
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
i took it in and had it inspected my drive shaft moves more then usual up and down it doesnt move left or right u-joints are good bushing is alowing car to clunk only on strait accel can this cause sever damage to my car if left alone and how much do u think repairs run
Received 1,676 Likes
Yes it will damage stuff. Eventually it will destroy the extension housing, if you let it go.
It's extremely easy to change out. If you take it out and hand it to a machine shop or a trans shop, it shouldn't cost more than about $20-25 to pay them to do it. If you have or can "rent" a bushing installer (I'm not sure whether VatoZone and those type places have those or not) then you can do it yourself. The bushing itself should cost less than $5.
Not to be the "signature police" or anything; but the LG4 is NOT the "HO" motor. It's the lowest output of any of the V8s available in these cars. The actual HO motor was the L69. It would be a good idea to remove that from your car description. You may find that some people might be a bit ..... offended ..... by your misuse of the "HO" designation, as if it was just a buzzword or something.
Car: 1985 TransAm
Engine: 5.0L TPI
your 100% right LG4 was chevys lowest powered motor so its a LO motor but i ment that the replacement 4BBL is off a HO motor
TMZIrocZ350
10-07-2015 12:09 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
