Gear help
Old Jun 26, 2006 | 10:36 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Gear help
i dont know much about rearend gears,but my question is, i have 2.73 gears right now and i would like to upgrade to 3.42 gears. which series to i get 2 series or 3 series? Also i was just going to get the richmond gears just ring and pinion is that all i need, the car already has posi.
Old Jun 27, 2006 | 03:19 AM
ede's Avatar
ede
you'd need a gear set to match your carreir, or a shim, or a carrier to match the new gear set, you have a 2 series carrier. i'd also get an install kit, solid spacer, and a new nut if it doesn't come with the kit.
Old Jun 27, 2006 | 07:43 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Also find a good installer, because you sound like you are novice and this is not DIY job to be learning on.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
