where can i get gears for a 9 bolt
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
I just got this 9 bolt for my trans am it's called the Australian 9 bolt and I was wondering where I could find like a 3.73 gear or something for it. Its a 7.75
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
depends on where you are at
there is a guy in LA named Toms differential and he was the only one i found who has able to get pricing for me but it was rather expensive so be forewarned. Realy there is nothing wrong with those 3.27 gears in there ... it will help you out with that freeway mileage too...
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you do a search? I got mine from Randy's Ring & Pinion at Randy's Ring & Pinion - Your Source for Differential Parts
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
