late 3rd and 4th gen question
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
I want to be 100% with this, but from what I have asked and what I found, I can use a stock posi from a 00 Trans Am in my 91 Camaro stock, non-posi housing because the axle splines are the same, am I right??
I want to get this right before I start taking things apart and not being able to put them back together, thanks all!!
As for the yoke and such, I have a complete donor 4th gen rear end, I just want to put a posi in my rear and have the 4.10 gear, any input is appreciated
anyone able to help me out on this one? I really don't want to pull it all apart and have it not work
Axle/Gears: '01 3.42 10 bolt
i thijnk it would be easier to swap complete rear ends. do a search but i think i read somewhere this would work. there is a thread about 3rd/4th gen interchangablity.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Yes, you can if you know how to setup rearends. I put a lsd from a 96 TA in a 86 firebird housing and used my old 28 spline axles to make my rear.
Thats the answer I wanted. I have setup a few rear ends in the past so I am confident enough I can do one more. Plus I work at an auto mechanics school as the tool room attendant, and have TONS of tools at my disposal to get it right the first time.
BTW anyone know where I can get the stronger pin and solid crush sleeve??
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
You can get a zytanium cross pin for the 7.625" rear-end at Welcome to Year One - part number: D66. It's $31.95.
Originally Posted by Casey Butt
Ratech makes a solid crush sleeve (GM Differential Small Parts). Part no. 4111 - $17.00
1992rs/ss
16
Jan 28, 2016 09:58 PM
