SHIFTING AT WOT
Old Jul 4, 2006 | 05:45 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
SHIFTING AT WOT
AT WOT MY CAR SHIFTS AT LIKE 4.5 GRAND AND I JUST AJUSTED MY TV CABLE IS THAT THE RIGHT SHIFT POINT
Old Jul 4, 2006 | 05:53 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The tv cable is used to control line pressure in the trans. By changing the line pressure, you will change shift points. However, this is harmful to the trans. Having the cable adjusted anywhere but it's correct location will kill the trans dead in short order.
Old Jul 4, 2006 | 05:58 PM
xgtharo86x's Avatar
Car: 86' Trans am
WHERE SHOULD I AJUST IT TO I DID WUT EVERYONE ELSE SAID TO HAVE SOMEONE PUT THE TRODAL TO THE FLOOR AND PULL THE CABLE OUT AS MUCH AS U CAN
Old Jul 4, 2006 | 06:52 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
Simply put the cable all th way back in the adjuster and pull it to wide open throttle,that is how you adjust it.
Old Jul 4, 2006 | 07:18 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Tech Articles - Adjusting Your Kick-Down Cable
Old Jul 4, 2006 | 08:59 PM
xgtharo86x's Avatar
Car: 86' Trans am
so your saying i hold the button while someone puts it to WOT and it will be agusted and do i pull ut out till no more comes out or till hits WOT and thats it
Old Jul 5, 2006 | 09:07 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Push the button, and push the adjuster housing back towards the firewall... Release the button, then slowly push the throttle all the way to WOT... It will ratchet out to the correct position.
Old Jul 5, 2006 | 12:40 PM
Shagwell's Avatar
Car: projects.......
for a factory cable. - to adjust shift rpm you have to change the governor. - Summit/Jegs list a governor recalibration kit with different springs and weights to properly adjust shift points.
- as stated, DO NOT adjust shift points with the detent cable. The detent cable only has one proper setting.
Old Jul 6, 2006 | 09:43 AM
Pro Built Automatics's Avatar
The correct way to see if you have adjusted this right is to open the carb or FI all the way (WOT) and see if there is any play in the TV cable, if these is more than a click, about 1/16", then tighten the TV cable to achieve this. Now this setting is very close to being as good as you can get. Now, if you have to change the WOT shift points, you do this with a governor weight & spring change, such as the B&M governor calibration kit.
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
