TCC intermittently unlocking
Old Jul 6, 2006 | 01:00 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
About two months ago I started to notice the converter unlocking intermittently during low load, steady speed cruise. This will happen about a dozen times usually in the first five or ten minutes of highway cruising. It does not appear to be related to changes in load or speed (in fact the tach will only flash about 100 rpms most times) and will lock back up almost immediately. It's a stock 85 LG4.
Any tips on diagnosing this puppy?
Old Jul 7, 2006 | 02:43 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Not sure about that, other than I'm sure that you might want to check TCC solenoid and or wiring for your 700r4. Perhaps a new TC will solve it.
Its the durndest thing, mine does exactly the opposite. I get intermittent TC lockup during ONLY the first 5-10 minutes of driving, then it goes away completely...... It's rebuild time I know...
Old Jul 7, 2006 | 06:58 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
lube the speedo cable
Old Sep 29, 2006 | 01:09 AM
nadster's Avatar
Car: 89 RS
Engine: 2.8 (the cruiser)
Transmission: 700R4 (TransGo Kit, VetteServo)
The speedo cable can cause this? That's what my problem is, the tcc will jump on and off after the car warms up during highway cruise. Guessing that a sticking spedo cable can cause the ecu to recieve a mixed signal?
Old Jan 10, 2007 | 05:04 PM
naf's Avatar
naf
Wanted to close this one, who knows someone may do a search one day...imagine that.
Anyway a test light at the ALDL showed that the ECM was commanding unlock (or more accurately intermittently failing to command lock). Problem remained intermittent (would go a week or more then come back) until one day I pulled an open circuit coolant temp sensor code. Swapped a new pigtail on the CTS and it's been more than three months now and no more problem.
I'm thinking that a speedo cable bad enough to affect the VSS would manifest itself in a bouncing speedo needle, but never been there so...
Old Jan 10, 2007 | 07:26 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
I was having that same issue, particularly locking the converter while I was sitting at lights after I had been on the highway In my monte. I replaced the solenoid and the problem went away.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Fronzizzle
Mar 18, 2019 08:29 PM
92camaro350cci
Oct 14, 2015 09:29 AM
ramicio
Sep 28, 2015 01:18 PM
Roblyons
Sep 12, 2015 10:29 PM
