T-5 noises
Old Jul 7, 2006 | 04:49 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
T-5 noises
when shifting down, in between all gears it seems * i can double check *
Makes a wining noise going into the next lower gear and is tough to push in then it pops in
im thinking it could maybe use some New tranny fluid and a few bearings but i dont feel like tearing into it atm
Old Jul 7, 2006 | 07:06 AM
Sounds pretty normal.
Think about what you're having to do when you downshift: you're speeding up the clutch disc from whatever RPM it happens to be at at the moment, to whatever RPM the engine will also be at in the new gear. So if you're going from let's say 4th to 2nd at 45 mph, that disc has to go from about 2500 RPM or whatever, to about 5000 RPM. That's ALOT ALOT of energy.
The whining noise is the countergear bearings and all the various other parts that have to speed up along with the clutch disc.
New fluid is usually a good idea, within reason. Just making sure it's full is pretty smart too. I'd leave the bearings alone though, since it doesn't sound to me like there's anything wrong with them.
Old Jul 7, 2006 | 11:58 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
My T5 makes the same noise, before rebuild, and after.
Old Jul 7, 2006 | 01:04 PM
Shagwell's Avatar
Car: projects.......
normal.
- the syncros have to come up to speed for a down shift, as with any other manual trans...
Old Jul 7, 2006 | 01:54 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
alright, good i just wanted to know... not to good with transmissions
I did notice a small leak coming from near the bellhousing * tiny drops*
so it could be a bit low... Ive heard various problems with people pulling the wrong plug etc
Is there a sticky guiding you on how to do a fluid change on a t-5?
Old Jul 7, 2006 | 09:22 PM
JB22's Avatar
The easiest way would be to pull the lower plug on the pass. side and let it drain out. Then remove your shifter and pour in the fluid through the shifter area.
If you dont do that, then you need to get one of those hoses with the caps or a funnel or something to get it in the top hole on the pass side.
I just did the first one pretty recently. Took about 10 minutes tops to pour in the 3 quarts of ATF.
I used Mobil 1
Old Jul 7, 2006 | 09:43 PM
top hole on the drivers side
NO!!! NO!!!!! NO!!!!!!!!
That's the one that if you take out, the transmission falls apart.
The drain and fill holes are BOTH ON THE PASS SIDE.
Old Jul 7, 2006 | 10:24 PM
JB22's Avatar
bleh... I edited it... Thats what I meant to say...
Old Jul 7, 2006 | 10:25 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
thank god you were a mere 21 minutes behind the last guy
Old Jul 8, 2006 | 12:17 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
ok Passenger side, the giant nut looking thing im guessing
it takes exactly 3 quarts?
Old Jul 8, 2006 | 12:45 AM
JB22's Avatar
I think the book says 2.9 quarts. But if your going to be going through the top plug on the pass. side it will run out if its over full.
Old Jul 8, 2006 | 12:58 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
i could drain it, plug the drain plug and then open the top plug, fill from the shifter and when it drains out of it its full
lol?
Old Jul 8, 2006 | 06:08 AM
Yup, that would do it.
Or, just dump in all 3 quarts. I doubt the extra ounce or 2 will hurt anything; especially not if the trans leaks. That just gives you a little extra time before it runs dry again.
Old Jul 8, 2006 | 03:25 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
cool thanks alot guys!
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
DARKmj16
Sep 9, 2015 04:07 PM
Randomtask2
Sep 7, 2015 05:06 PM
