700r4 problems - Pennsylvania
Old Jul 16, 2006 | 12:18 AM
kgeary's Avatar
Car: 1985 IROC-Z
Engine: 355 - Miniram, AFR Heads
Axle/Gears: Dana 44 - 4.09
I am looking for a reputable transmission shop near Pittsburgh to do a high performance rebuild on my 700r4. I need if to work at 7,000 rpm adn be able to handle 550HP.
Thanks,
Old Jul 16, 2006 | 11:25 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
doubt your gonna find anyone near pitsburg... but check these guys out -
700R4.COM - Bowtie Overdrives
Old Jul 18, 2006 | 05:42 AM
Pro Built Automatics's Avatar
I have someone in Boyertown Pa, that builds for me when I get overloaded. He has been building for me for the past several years with very little problems. He builds exactly the way that I do as I supply everything for him, and comes with the same warranty. Which torque converter are you planning on using? If you want him to build this for you since he is closer than I am, let me know?
Old Jul 19, 2006 | 12:12 AM
kgeary's Avatar
Car: 1985 IROC-Z
I had this transmission built by you several years ago. I have had some problems with it from the beginning. The transmission does not always want to shift into third gear and at the top of third gear it goes into nuetral and won't stay in 4th at full throttle. I purchased it at least 5 years ago and have not done alot with the car since then as I had some heatlh problems to deal with. I did talk with Dana on the phone in the beginning and he felt that it was something (I don't remeber what) that would require taking the front pump out to fix. Since it work some of the time and given my health issues at the time I decided to just live with it.
Since you built this transmission and it does not have more than 3,000 miles on it would some of the parts be able to be used again and keep the cost down?
I would have interest in having your person in PA do the work.
I appreciate your reply.
Kris Geary
Old Jul 19, 2006 | 02:30 AM
Call me and I will will take care of this.
Old Jul 19, 2006 | 01:00 PM
Shagwell's Avatar
Car: projects.......
^^^^^^^^ - that's the kind of customer service I like to hear.
Dana
Old Jul 20, 2006 | 02:58 AM
It has been taken care of, to everybodys satisfaction.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
