swapped from an '85 to an '88 700r4- cable difference- problem
Old Jul 18, 2006 | 04:45 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok an 85 with factory Q jet, is what im working on
the 700r4 was burnt up
so i took an 88 700r4 and put in place of the fried 85 700r4 tranny
the 88 was a TBI 350
the cable on the 88 is alot shorter than the 85 one was
the 85 cable was burnt melted junk
the hole in the case on the 85 tranny for the tV cable end and seal to go into is alot bigger than the 88 is
what do i do ?
why did they change this size ?
thanks for anything
Old Jul 19, 2006 | 11:51 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ttt
Old Jul 19, 2006 | 12:49 PM
Shagwell's Avatar
Car: projects.......
head for the parts store and get a new cable.... - the aftermarket cables are built utilizing the smaller cable end - when used for the large hole, the factory type cylinder+washer gasket is used, the later models just usually just use a washer type seal.
Old Jul 29, 2006 | 02:05 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
interesting
the only applications i am gonna be able to use is one for a car in 88 for carb sbc engines
in 87 i dont know if the hole in the tranny case was small or large for the cable bolt up
or in 86 either..
hmmm
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
