383 and manual trans
Old Jul 20, 2006 | 09:28 AM
casebaseball205's Avatar
how hard is this swap. a guy is lookin to buy my car and wants to do this and is wondering.
6speed will bolt of or will a t5 be needed?
Old Jul 20, 2006 | 10:26 AM
No reason the T-56 won't bolt to a 383, same as it would to a 305 or 350. All the same swap issues (or lack of them) would apply.
Old Jul 20, 2006 | 12:06 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Everthing bolts up just fine, one thing you want to keep an eye out for is the aftermarket 1 pc rear main crank. On my cast steel Eagle 383 crank, it seems to stick ever-so-slightly futher out the back than the stock crank. This has caused me to have T-56 clutch fork issues with rubbing on the pressure plate when the clutch is pressed all the way in. I did some minor clearencing on the clutch fork with a grinder, and it seemed to take care of the problem. Just a thing I noticed on my 383 and T-56.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
