hughes took a dump
Old Jul 22, 2006 | 01:24 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
hughes took a dump
ok about month ago i picked up a used hughes transmission with converter everything looked good with the trans
i've been driving the car for about a month and about 2 days ago i noticed it started slipping trans temp was about 160* and the color and level was perfect in the trans.
it got to the point if i gave it any gas the rpms would climb but very slight movement and i could'nt even feel it shift. 1st to 2nd shift felt ok beyond that i could'nt feel it shift. i have been reading that it's probably the 3/4 clutch or tv cable not adjusted
can i just get a rebuild kit from hughes and that would fix it ? and would it come with the 3/4 clutch?
thanks
gta892000
Aug 11, 2019 11:16 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TBRays98
Sep 6, 2015 05:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
