aluminum drive shaft
Old Jul 24, 2006 | 12:40 PM
driver8's Avatar
Car: 87 Iroc
Engine: 383
Axle/Gears: 3:73
Does aluminum drive shaft really make a diffferance
Old Jul 24, 2006 | 12:57 PM
Shagwell's Avatar
Car: projects.......
seat of the pants difference? no. Difference in general, yes. Hell, pro-stockers run carbon fiber shafts that wear out in a race or two, rifle drilled axles, titanium spools, etc all in the name of reducing the centerifcal weight.
You won't really notice a difference until you have much more power than stock, then you still probably won't feel it, it'll just show on time slips. - It also helps driveline items(bearings, u-joints, etc) live longer.
Old Jul 24, 2006 | 01:02 PM
driver8's Avatar
Car: 87 Iroc
Engine: 383
Axle/Gears: 3:73
do you know what diameter of the stock drive shaft is?
Old Jul 24, 2006 | 08:24 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Stock steel 3rd gen dr shaft should be 2 5/8 dia. The ILE Aluminum is 2 7/8 dia.
Old Jul 24, 2006 | 09:00 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I think the best reason to have an aluminum driveshaft is becuase there is less weight and less vibration........if I could find a way to put one on my 62 caddy i would.........
Old Jul 25, 2006 | 09:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you are having vibration issues with the stock steel shaft, the aluminum shaft makes a world of difference. It is the one single reason there is one on my '92.
RBob.
Old Jul 25, 2006 | 10:24 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
RBob.
in fact, if you took your car back under waranty and complained of "vibration at cruise" your car was usualy given an aluminum driveshaft and aluminum brake drums to fix the problem.
Old Jul 25, 2006 | 12:48 PM
Shagwell's Avatar
there's no reason for a steel shaft to have any more vibration than aluminum, unless it's bent or mis-balanced.
Old Jul 25, 2006 | 01:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its driveline harmonics and the critical (speed of the shaft) that the aluminum takes care of....
and yes aluminum is better (srtonger and lighter)... something to do with the driveshaft spinning faster than the motor in cars with a overdrive trans...
Old Jul 25, 2006 | 06:00 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Since when is aluminum stronger than steel?
Old Jul 26, 2006 | 08:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, unfortunately I found out about this too late. I know some one that purchased an '87 Camaro, new. Had severe vibration problems that the dealer couldn't fix. Ended up selling the car.
With mine, once the aluminum shaft was installed I had to keep a good eye on the speedometer. The car is so smooth that I found myself cruising at higher speeds.
RBob.
Old Jun 6, 2007 | 02:42 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Re: aluminum drive shaft
Sort of. Pound for pound certain alloys of aluminum can be much stronger than steel. When we are replacing steel components with aluminum ones in our case for weight savings, we are always compromising the strength and longevity of the part.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
