GTA rearend
Old Jul 26, 2006 | 07:01 PM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
GTA rearend
Are GTA's 9-bolt? I know they come stock with 3.27 gears but can't get a clear answer if they are 9 or 10....I heard that only GTA's are 9 bolt and that is kinda rare. I can't check my car since I am away. Also, if they are 9 bolt, does anyone know a good place to buy 4.11 gears for them?? Everything is for 10 or 12...
Old Jul 26, 2006 | 07:15 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
3:27 gear ratio is for a 9-bolt. You are SOL finding 4:11 ratio for that rear. Just run what you have or spend $2500+ for a 12- bolt.
Old Jul 26, 2006 | 07:25 PM
Engine: 355 TPI
I'm pretty new to rearend stuff. I'm more into stuff involved with engines so sorry if it seems like i don't know what i'm really talking about. Is there any kind of gear out there for a 9 bolt higher than 3.27? I may be doing some more upgrades to my engine and I want to make sure power is getting to the wheels. Will a 3.27 support a supercharger?
Old Jul 26, 2006 | 08:18 PM
DJP87Z28's Avatar
You mean a lower ratio, a 3:45 is lower and 2:77 is higher then the 3:27. The only ratio that may be avaible for the 9-bolt is a 3:73 which will be the lowest ratio out there.
Old Jul 27, 2006 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A search is a good thing on this site. The info here may help:
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
Old Jul 27, 2006 | 01:01 PM
Shagwell's Avatar
Car: projects.......
they do make a 4.10 for a 9-bolt, but it is very hard to come by. The 3.70 is available from a few sources.
Gear ratio has nothing to do with supporting "X" power. The steeper(numerically lower) of a gear you can truly "pull" the faster you'll be.
Old Sep 9, 2006 | 11:13 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Its actually a 3.70
Old Sep 9, 2006 | 09:47 PM
REDTAIL's Avatar
Car: 86 iroc 92 rs parts car
Engine: 350 305
Transmission: t5 t5
Axle/Gears: 3:73, 3:08
only in top speed
Old Sep 10, 2006 | 03:03 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally Posted by REDTAIL
only in top speed
Not necessarily. For really torquey motors with little top end power, steep gears are better. for example... it would run out of gear too quickly if you had a stock 350 that topped out at 4200 rpm and you put something like a 4.10 gear behind it, and you'd spend more time between gears than actually accelerating the car (with a manual trans)
If he has a relatively stock TPI engine in the GTA, then he'd be best off with something like a 3.45 or 3.70 gear, not a 4.10.. thats way too much gear for a TPI motor.
Old Sep 10, 2006 | 06:18 AM
Pat Hall's Avatar
If his car is actually a 91 GTA like his info says, then it's a ten bolt, not a nine bolt. The last year for the nine bolts in any of the f-bodies, including GTA's was 1989. The rearend in my 89 RS is out of a 91 GTA 5.7 auto car, and it's a pbr disc brake, 3.23 ratio, posi ten bolt. I also pulled the gears and posi carrier from another 91 5.7 auto GTA in a local junkyard, and it was also a disc brake, 3.23 ten bolt rear. If you find a 91 GTA with a 5 speed, it's usually a 3.42 ten bolt.
Old Sep 10, 2006 | 06:22 PM
REDTAIL's Avatar
Engine: 350 305
Transmission: t5 t5
all right i think i just realized where i or someone else got confussed.around here steeper gears usally means higher numbers i.e stump pulling gears 4:56
plus your talking about 1/4 mile times. in any 60 foot 4:10 will kill 3:42 on same car,but will run out of gear at the end that's why they say set up third gen to hold 3rd gear at line
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
