bad knock in reverse
Old Aug 7, 2006 | 06:53 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
ok people this is my problem i have a 1992 z28 and every time you put it in reverse it does a bad knock then its fine, it only knocks when you first put it in gear it just started happening today. any ideas what the problem is?
Old Aug 7, 2006 | 07:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Does it knock when you put it in drive from reverse? Could be something like a transmission mount, torque arm bushing, U-joint...
Old Aug 7, 2006 | 07:06 PM
Axle/Gears: G92
no thats the werid thing it only knocks when you put in the reverse gear never anything else only when you put in reverse if you put in drive it doesnt do a thing....
Old Aug 7, 2006 | 07:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Can you jack it up to look underneath while someone sits inside and puts it in gear?
Old Aug 7, 2006 | 07:15 PM
Axle/Gears: G92
no not really.......
Old Aug 7, 2006 | 07:21 PM
Axle/Gears: G92
what were you thinking with the jacking up the car
Old Aug 7, 2006 | 07:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could see if any parts lurched when it was put into reverse, which would point the problem. If everything's tight, it might be an internal transmission problem.
Old Aug 7, 2006 | 07:27 PM
Axle/Gears: G92
ok thank you for the info i will try to figure it out
does anyone know what this problem might be?
Last edited by david068513; Aug 7, 2006 at 07:31 PM. Reason: Automerged Doublepost
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
