Rear end fluid in the transmission
Old Aug 9, 2006 | 04:22 PM
RustInPeace's Avatar
I just bought a 86 camaro but discovered there was rear end fluid in the transmission does anyone know if this does anything to the transmission, like hide noises or something please help.
Old Aug 9, 2006 | 05:19 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Let me guess, its a standard...
If so somone probably goofed and put in gear oil instead of the (i think) reccomended ATF.
If its in an auto tranny, you have some serious issues!
Old Aug 9, 2006 | 05:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you have a T-5, it's supposed to have gear oil.
Old Aug 9, 2006 | 06:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i hope you have a stick or you could have a real messy situation
Old Aug 10, 2006 | 03:45 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Common misconception. The T5 actually takes ATF, and was designed to be that way. Before I bought my 84' , the trans was rebuilt and someone put gear oil in it. The seals deteriorated prematurely. Upon it's second rebuild, the T5 is holding up as it should with ATF, as per the service manual (dexron II).
When it did have gear oil in it, it was actually noisier, and was a PITA to shift when it was cold. The four speed takes GL-5, SAE80, or 80W-90 gear oil.
Old Aug 10, 2006 | 05:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The W/C T-5 takes ATF. The T-5 takes gear oil, or did originally at least when it left the factory.
Old Aug 10, 2006 | 06:12 PM
Zed'er's Avatar
Car: 84 Z28HO
Well, the blocker rings in my non-w/c T5 didn't like the 80W-90 at all. Maybe I have a hybrid, lol.
Old Aug 10, 2006 | 06:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well, the repair manual says ATF for the T-5 too, but the only two non-W/C T-5 cars I've seen both had gear oil as their factory fill.
Old Aug 10, 2006 | 08:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
most aluminum case trannies and transfer cases used ATF
are a few exceptions, but not many
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
