Changing Fluid/Filter
Old Aug 10, 2006 | 02:15 PM
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
IM in the middle of changing my fluid and filter but the crossmember is in the way for the rest of the pan bolts, do you usually need to remove the crossmember to take the pan off?
Old Aug 10, 2006 | 02:21 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
you might have to, i got a different pan and the bolts are different size so i just cut the crossmember a little bit. i dont know if you have to on stock size bolts or not
Old Aug 10, 2006 | 02:30 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
If you gotta move it, then you gotta move it. There's only four bolts holding it on , not much trouble at all.
Old Aug 10, 2006 | 02:38 PM
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
When i take it off do i have to worry about supporting my trasmission while its off with a jack or something
Old Aug 10, 2006 | 02:57 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
yes, otherwise the distributor will hit the fire wall (V8). I changed mine without removing the xmember, takes a little thinking to get it back on sometimes
Old Aug 10, 2006 | 03:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A jackstand under the tailshaft housing will keep it up.
Old Aug 10, 2006 | 05:39 PM
Car: 87 trans am
ive never put a jack under it, i just let the six bolts hold it up, my distributor doesnt hit either, but now that i cut the crossmember a little, dont have to worry about supporting it
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
