melted line
Old Aug 14, 2006 | 09:14 PM
jetin85's Avatar
Car: 85 TRANS AM WS6
Engine: rebuilt 350
melted line
are T-5 hydrolic lines hard to find?? I burned a 1/4 inch hole when my car missed fired a shot flaming gas through the air and hit my master too slave hydrolic line ouch!!!! or is this repairable??
Old Aug 14, 2006 | 09:37 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
If i remember right when my friend bought his master cylender it came with one.
Old Aug 15, 2006 | 04:16 AM
jetin85's Avatar
Engine: rebuilt 350
Did he get it from a normal auto parts store or did he order it??
Old Aug 15, 2006 | 08:34 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
you can not buy just the hard line. You either have to pull the aluminum ends out of the original one and make your own, or buy a whole clutch slave and master assembly from GM. It is expensive but I just bought the whole assembly from GM and called it a day. Way less headaches.
Old Aug 17, 2006 | 03:30 AM
Pat Hall's Avatar
You could get one for next to nothing if you can find a manual f-body in the junkyard. The 6 cylinder ones are identical to the V8 ones. If you want to upgrade, the fourth gen cars use a stainless steel braided line instead of the plastic one, and they bolt right up on a thirdgen. You can buy the complete assembly from GM for about $160, or you can get lucky like I did and find a fourth gen setup in the boneyard for dirt cheap.
Old Aug 17, 2006 | 08:44 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I think the only ones with a stainless line are the LS1 powered cars correct?
Old Aug 17, 2006 | 11:44 PM
Pat Hall's Avatar
I actually pulled mine off a 95 firebird with a 6 cylinder in it. Not sure if they started using the stainless line right in 93, but 95's have them.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
corey8084
Sep 17, 2015 02:56 PM
TBRays98
Sep 6, 2015 05:05 PM
