Need speedo help
Old Aug 16, 2006 | 09:04 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Need speedo help
Hey guys, well my speedo on my 1984 pontiac firebird is missing a cable of some sort. My local parts stores cant seem to find the right part that goes between this sensor and transmissiong. Im really confussed and have no idea what part i should be looking for. Any help will be much appreciated. Heres some pics...
Also the trany is a 700r4 auto
Old Aug 16, 2006 | 09:27 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Are you talking about that 2 inch long or so piece of square cable that goes into the gear and then into the sensor? If so I do not know where you will find one... I do not think a standard parts store will have it though, and you may need to go to the dealer. or go to a salvage yard and pick one up. probably will cost you a whole 50 cents.. or if you are good you can cut a new one out of some steel stock.. a bit of work for sure. but they are stronger than the stock thing...
I had to replace my little part though.. I just went to the salvage yard... I did have to fabricate the metal retainer thing that keeps the housing in the transmission from falling out.. the stock one was actually to thick for my speed sensor.
Old Aug 16, 2006 | 09:50 PM
Car: 84' Trans Am
I have no idea, but it has to go from that sensor to the transmission.
Old Aug 16, 2006 | 09:57 PM
Car: 84' Trans Am
Is there any way to bypass that sensor and directly hook up the main cable to the tranny?
Old Aug 16, 2006 | 10:05 PM
Car: 84' Trans Am
Also does anybody know if i cant still order that square cable thing at the dealership?
Old Aug 16, 2006 | 10:08 PM
Car: 84' Trans Am
I had to replace my little part though.. I just went to the salvage yard... I did have to fabricate the metal retainer thing that keeps the housing in the transmission from falling out.. the stock one was actually to thick for my speed sensor.[/quote].....................Does that part break often? I hope that the senser in the tranny didnt strip out.
Old Aug 17, 2006 | 10:47 AM
Car: 84' Trans Am
Bump...Also does anyone know what that part may be called, going to try to order one from the dealer?
Also has anybody ever seen that sensor, i was told its aftermarket?
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
