Sensor issue with Swapping a 4th Gen Rear into an '83
Old Aug 26, 2006 | 05:02 PM
1983-Z's Avatar
I just picked up a 10 bolt 3.42 Posi from a 1997 Trans Am.
Planning to install it in my 1983 Z-28.
There is a sensor on top of the pumpkin. VSS? Traction Control? ABS?
I'd like to know if it's going to cause me problems if the sensor is not used.
I'm only worried about the function of the rearend, brakes and that the Posi will function as it should.
Any help/info is greatly appreciated.
Old Aug 26, 2006 | 08:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's probably ABS - my 2000 LS1 rear end had it when I swapped. Won't bother anything, just don't connect it to anything - everything else will function normally.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mizz0313
Aug 12, 2015 06:45 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
