currie 9" rear question
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i tried doing a search but it was acting all funny. im looking into purchasing the currie 9" housing and axles in jegs. it says that you have to use there rear brake setup. which disk brake kit works or can i use the factory disks. thanks for any help.
I purchased mine from Currie direct. I sent them my disc brake mounting brackets, and they modified them, and installed them on the 9" rear. The center of the bracket will need to be enlarged to fit the large axle tubes of the 9". I currently use my origional disc brakes on mine. I sent them a new set of ARP metric wheel studs too, and they were installed too.
I would recommend dealing with Currie, so (just in case) if there is a problem, you can deal with them. I had no problems whatsoever with them.
