Worn out trans?
Old Aug 30, 2006 | 02:43 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Worn out trans?
So, I know that with the 700R4 the kick down (or TV) cable needs to be hooked up so the trans shifts properly. But, what about the THM 350? In my Nova, I have one and when I rebuilt it, I used a stock rebuild kit, but added a shift kit to it. When I first installed it, it gave "break neck" shifts, and off the line, it would launch hard. But lately the shifts have smoothed out, and off the line, there feels like some lag, or maybe some siipping. I have had this trans in my Nova for about a year & a half, and some really really hard miles. (I don't baby this car one bit!!) The kick down cable has never been hooked up, and I have a 2500 RPM stall TCI converter in it. When I go through the gears, it feels like the trans holds (no slipping) but I'm wondering if the clutches are starting to go? I doubt that the converter is going, but I could be wrong.
One day I pulled the dipstick to check the level, (due to a leak at the dipstick tube I need to check the level regularly), and the fluid smelled burnt. So I drained & refilled the oil, and added some Lucas additive. But the condition still exists.
Old Aug 30, 2006 | 03:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The kickdown cable on a TH350 is different from the TV cable on a 700R4. It doesn't need to be connected, as long as you don't mind that the transmission won't downshift when you put your foot into it.
Fronzizzle
Mar 18, 2019 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
db057
Sep 4, 2015 07:57 AM
someone972
Aug 30, 2015 12:52 AM
