Driveshaft Swap
Old Aug 30, 2006 | 05:36 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
Driveshaft Swap
I have an aluminum driveshaft out of an 88 IROC 350. I tried to bolt it in my 86, and the u-joint on the driveshaft was a different size and wouldn't bolt up to my rear. I know the 88 had a Borg-Warner rear and I have a GM 10 bolt. Is there a special u-joint that I can use?
Old Aug 30, 2006 | 07:04 PM
Car: 86 IROC
Engine: 350 Miniram
anyone?
Old Aug 30, 2006 | 07:57 PM
Car: 86 IROC
Engine: 350 Miniram
So... noboby has ever put an aluminum driveshaft on a 10 bolt (not a 9 bolt B-W) rear?
Old Aug 30, 2006 | 08:31 PM
ssean92's Avatar
Car: sold
they are the same
Old Aug 31, 2006 | 01:46 AM
Pat Hall's Avatar
You might want to check and make sure both your bearing caps are completely seated on the u-joint because both the 9 and the 10 bolts use the exact same u-joint.
Old Aug 31, 2006 | 05:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
On pre-88 cars, the rear U has to be swapped out. I used CarQuest part number 3-3130.
JamesC
Irocguy01
Sep 28, 2015 02:03 PM
theshackle
Aug 23, 2015 03:49 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
