changing rear fluid
Old Sep 2, 2006 | 05:00 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
changing rear fluid
anybody got some tips for me on what i should use to fill my rear the bottle has no room to tilt to fill it up. also the last owner used silicone instead of a gasket what should i use to scrape the old silicone off so i can get a nice clean area to put the new gasket on.
Old Sep 2, 2006 | 05:15 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Use some of that clear rubber hose or tubing, to remove the gasket use a putty knife, a razor blade, or anything like it.
Old Sep 2, 2006 | 05:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a hose work very well
Old Sep 2, 2006 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Most auto stores sell a small fluid pump with a plastic hose ($3 or $4), which screws onto a bottle. Easy as pie.
JamesC
Old Sep 4, 2006 | 10:21 AM
Pat Hall's Avatar
You can put a gasket in if you really want to, but it isn't necessary. If you clean the mounting surface with a good solvent like brake parts cleaner and just run a 1/4" bead of good silicone sealer like "the right stuff" from permatex, it'll seal up just fine without a gasket. I haven't bought a gasket in years for any of mine. And like JamesC said, just pick up a gear lube pump from a parts store for a few bucks to put the lube in. Makes it easy as pie.
Old Sep 4, 2006 | 05:37 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
got the fluid changed today
it was really easy bought some high performance valvaline 80w90 (2 quarts) a 7 oz bottle of limited slip additive a felpro rear differential cover gasket and a fluid pump for about 30 all together. The hardest part was cleaning the old sillicone off the cover and rear (the old owner didnt use a gasket and it leaked pretty bad. I recommend this for anybody who has a car with alot of miles on mine fluid was pretty dirty. Hard to fit a ratchet in some places and had to use a wrench but like i said easy job.
customblackbird
Aug 15, 2021 10:16 PM
maroe624
Apr 16, 2017 08:29 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
