T5 shifter problems
Old Sep 3, 2006 | 06:54 PM
SBRacing's Avatar
Car: 1983 Camaro Z28
Engine: 5.0/305
Transmission: Manual 5-Speed
Axle/Gears: Not sure as of now
T5 shifter problems
For some reason the shifter in my car doesnt work while the car is on. When it is off the shifter moves freely through all 5 gears including reverse and the walls are there. When the engine is running, gears 1,4, and 5 NEVER work. Gears 2 and 3 have to be beaten into gear. Reverse grinds when trying to put it into gear, WITH THE CLUTCH FULLY PRESSED, and has to be thrown into gear and then the car jumps. While driving, you can get it into first gear but its a bitch, and sometimes the gears dont catch even when in the exact spot, as if they move??? lol, and ALL the gears are VERRY difficult to get in gear. I think my clutch is fine, not sure tho, supposedly it is a high performance racing clutch, and it catches fine. can someone PLEASE help!!!!
Old Sep 3, 2006 | 07:01 PM
Not a shifter problem.
Not a transmission problem.
It's a clutch problem.
Most likely, incorrect assembly.
When you put your clutch fork and throwout bearing together, which of these 2 pictures did it look like?
Old Sep 5, 2006 | 04:17 PM
SBRacing's Avatar
Engine: 5.0/305
Im not the one who put it together, i bought the car like that, so i relle dont know. Thanks for the input tho, ill rip it apart this weekend and check.
Old Sep 5, 2006 | 05:26 PM
It's a very common mistake, so that's a good place to start.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
neekolzun
Aug 24, 2015 04:59 PM
