T.V adjustment / idiot alert
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
well my '87 camaro with a 700R4 wont shift out of first , so i've done a search and found that the first thing to do is adjust my T.V cable. i have looked at the tech post on how to do it but i cant seem to find the lever on my TPI engine. i can see a lever with cables going into it on the right hand side of the tpi unit ( as you look at the engine ) but there does not seem to be any way of adjusting it , and i cant seem to find a metal tang to push as the article states.
please help , im going mad. a picture of the lever and metal tang would be ideal, there is a pic on the tech page but i cant make it out and it does not resemble whats on my 350 TPI
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Engine: 350 L98
yeah i did read that but i cant find any sort of metal tang on the lever. i must be stupid
ahhhhhhhhhhhhhhhif someone could post a pic of the tpi tv lever that would be really helpful
Engine: 2.8/3.1
Transmission: auto
The "D" tang is not on the lever. Find the cable end of the TV cable on the throttle body - it has a plastic connector on it. Follow that cable back towards the intake plenum to the plastic stop which protrudes through the plenum on the V6 (not sure on the V8). The "D" tang is behind that stop, usually underneath the plenum (on the V6 at least).
This article has some better pictures (it's on a carbed car but the cable and adjustment tang are the same).
Bowtie Overdrives | TV Made EZ
I don't know why your car isn't shifting out of first, but check out this post and what fixed the problem.
https://www.thirdgen.org/forums/tran...shift-out.html
Engine: 350 L98
i then checked the governer and that was fine and clean so there is something deeper at hand here. any suggestions ???
i will select first / reverse / second and drive but will not up shift. ahhhhhhhhhhhhh
LT1Formula
Oct 8, 2015 08:34 PM
