how to find out if tranny has a lock up converter
Old Sep 14, 2006 | 01:08 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I have a 1984 Z28 with a 700r4 how would you figure out if the stall converter is a lock or non lockup?
Old Sep 14, 2006 | 01:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's a stock converter, it has a clutch. If it's an aftermarket converter, it almost certainly has a clutch unless it's some kind of racing converter with an insane stall.
Old Sep 14, 2006 | 02:38 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I have a 3,000 stall converter. I'am aslo wondering because I got antoher tranny and its out of a 86 blazer if that matters. I just put in a 355 motor and I want to yank the computer out because I have no emissions stuff anymore. The only thing I can think the computer might be need for is the tranny. Any suggestions??
Old Sep 14, 2006 | 03:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, the computer controls the locking of the torque converter. Computer or not, a stock 700R4 needs the torque converter to lock.
By "no emissions" stuff, do you mean you no longer have the computer controlled carb and distributor as well?
Old Sep 14, 2006 | 03:33 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I have no air tubes, cat conveter,cc carb,or cc distributor,or smog pump. With all of that not there the computer will still control the covertor well ?
Old Sep 14, 2006 | 03:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, computer control is all or nothing. There are a dozen and one ways to get the TCC to lock without the computer, though.
Old Sep 14, 2006 | 03:55 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
If i dont get a switch for the coverter what will happen when i drive it?
Old Sep 14, 2006 | 05:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll be giving up some gas mileage, and flow to the cooler will be reduced, causing excess heat in the transmission and reduced life.
Old Sep 14, 2006 | 06:13 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Any decent tranny shop should be able to wire a pressure switch in the valve body assy to control the tcc.
Old Sep 14, 2006 | 08:46 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Dont drive it like that. My friend took off his CC carb and distributor and burnt his trany up in less than a week.
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
