v6 trannys
Old Sep 14, 2006 | 06:17 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
v6 trannys
what all automatic transmissions with overdrive came in the 92 v6. was it just the 700r4. if so will that 700r4 off of the v6 fit onto a chevrolet 350
Old Sep 14, 2006 | 07:25 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Yeah, 700R4 was the only automatic available on a '92. I believe the bellhousing would have to be changed to fit on a small block.
Old Sep 14, 2006 | 08:41 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Yes its a 700R4, but the bolt patterns are different and you cannot change them.
Old Sep 14, 2006 | 09:26 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
ultrabell it and it will fit with a new input housing or a custom converter
Old Sep 14, 2006 | 10:49 PM
RSFreak's Avatar
Well, I was partially right. I knew you couldn't just swap it over.
Old Sep 15, 2006 | 06:12 AM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
ok well ill just go buy another 700r4. it needs rebuilt but its only $50 for it.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
