What spicer u-joint should I get?
Old Sep 8, 2006 | 03:56 AM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
I need new spicers to the driveshaft of my car. When I accelerate there is shaking coming from the drivetrain area. I've replaced alot of bushings so guess this is all that's left out.
It's an '89 GTA with 305 TPI (LB9) and manual transmission. I already got a pair of spicers from the shop but after measuring the old ones they seem to be too big. So what is the correct model spicers to get to my car? What should I for example look for on ebay?
Also, does the shaft have to be balanced afterwords?
Old Sep 8, 2006 | 10:57 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is your driveshaft steel or aluminum? 9 bolt or 10 bolt rear?
Old Sep 10, 2006 | 08:58 AM
Car: Red '89 GTA
Engine: TPI LB9
did it ever come with aluminium? It's stock. And it's a borg warner 9 bolt rear and t-5.
Old Sep 10, 2006 | 05:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yes some did come with aluminum
Old Sep 11, 2006 | 03:27 AM
Car: Red '89 GTA
Engine: TPI LB9
how can i tell which is which?
Old Sep 11, 2006 | 10:16 AM
ede's Avatar
ede
you can tell by getting under your car and looking
Old Sep 11, 2006 | 10:31 AM
Car: Red '89 GTA
Engine: TPI LB9
If i had to guess I'd say steel but I can't tell for sure.
Old Sep 11, 2006 | 10:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If a magnet sticks to it, it's steel. If it doesn't stick, it's aluminum.
The steel and aluminum shafts have different yokes and take different U joints.
Old Sep 11, 2006 | 10:58 AM
Car: Red '89 GTA
Engine: TPI LB9
Thanx! Good idéa. I'll try that soon.
Old Sep 13, 2006 | 07:44 AM
Car: Red '89 GTA
Engine: TPI LB9
I haven't had the chanse to check yet, but does anyone know the type of spicer that should fit steel or the aluminium type?
Old Sep 14, 2006 | 10:25 AM
Car: Red '89 GTA
Engine: TPI LB9
Okay, now I've checked weather it's a steel or aluminium shaft. Magnets stick to it so steel.
Does anyone know what spicer fits?
I'm attaching a pic of the spicer I got from a mechanic which seem to be too big.
Old Sep 14, 2006 | 11:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the right one for a stock steel driveshaft.
Old Sep 15, 2006 | 08:52 AM
Car: Red '89 GTA
Engine: TPI LB9
The new spicers look very different from the old ones. Will they actually fit? Can someone explain how the front spicer is fitted? Is it just with four clips? Or how do I remove it? And do I have to balance the shaft afterwards?
Here's a pic of the spicer u-joint on my car now.
MrJ
Jun 5, 2002 11:33 AM
FastBroker
Jun 3, 2001 07:15 AM
