Driveshaft length
Old Sep 15, 2006 | 03:33 AM
1986camarojoe's Avatar
Car: Z28
Engine: 310
Driveshaft length
I'm in the middle of a 6 inch tailshaft th350 swap and was wondering if anyone knew how long the driveshaft needs to be, is it just 3 inches longer? Also with my B&M torque arm mount it says I need some other outter torque arm mount and gives a GM part number. So I went to the dealership and they have 2 different ones and they don't know which one I need. Any help is appreciated, thanks.
Old Sep 15, 2006 | 05:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i believe that the two torque arm mounts are as follows, the torque arm its self has 2 "lips" formed on the end one style has the "lips facing the driver side, the other, passenger side. as for the driveshaft, you need to measure the distance between the centerlines of the trans yoke u-joint and the pinion yoke u-joint
Old Sep 15, 2006 | 07:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For the 6" tailshaft TH350, you can use the driveshaft that came in the 82-83 f-bodies with the metric 200 tranny (3 speed auto). It's close enough for the proper length.
Old Sep 15, 2006 | 10:29 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
from center of ujoint to other ujoint is 44.5 inches. You dont need to get another torque arm mount. You take your old one and grind the ridges for it to fit into the B&M kit.
Old Sep 16, 2006 | 07:12 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
200C shaft is the one needed
is the same length d shaft
if you woulda gotten a 9" tail th350 then you coulda used an easy to find 700r4 t-5 D shaft
good luck
wigmobile
Feb 26, 2025 02:56 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
Scorched1984
Sep 15, 2015 03:42 PM
